Oil pump shaft
  • Thread starter Thread starter 89bluegt
  • Start date Start date Dec 10, 2004
89bluegt
95
SC
Dec 10, 2004
  • Dec 10, 2004
I'm almost finished putting my engine together and I noticed that the oil pump shaft was not put in. Damn! I'm gonna try putting it in from the top. I 'll put a dab of silicon on the tip to hold it in the pump. If I drop it, then I'll take the pan back off.
Anyone else ever done this?
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Dec 10, 2004
  • Dec 10, 2004
I'd put it in from the bottom with the clip since you're so close anyway.
EMW150
2,020
Roaring Spring,PA
Dec 11, 2004
  • Dec 11, 2004
If you put it in from the top you can't have the clip installed. This could be ok till the first time you pull the distributor and it falls in the pan. If you already have the engine out do yourself a favor and pull the pan so you can install with the clip.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 11, 2004
  • Dec 11, 2004
EMW is spot on - don't take a short cut now; it will almost certainly lead to a real pain in the butt later. Pull the pan and pump and put it in from the bottom with the clip.
wyominghotwheel
156
Insanemustangs
Dec 11, 2004
  • Dec 11, 2004
yup, chances are it's gonna fall......i did the oil pump and shaft with the motor still in the car.....just undo the motor mount bolts, jack up the motor at the front near the dampner, drop the pan, won't come all the way out, but close enough.........then up in your shaft, and button it all back up..........hotwheels
89bluegt
95
SC
Dec 13, 2004
  • Dec 13, 2004
I decided to pull the pan off. I don't want to have to pull the engine later just to get the shaft out of the oil pan. Thanks for convincing me to do the right thing!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 13, 2004
  • Dec 13, 2004
You get the credit for LISTENING!! You'll be glad you did.
J
JeepN95YJ
  • Nov 14, 2005
Well, I read many of the posts concerning forgetting to put the oil pump shaft in before bolting up the oil pan. It is nice for me to see that I am not the only dummy who forgot to do this (what i get for working on chevys). I hope others will find comfort in sharing my misery as well.
Here is what I'm going to try...Heatshrink tubing. I'm going to stick that shaft in the distributor and use heatshrink tubing to keep it from falling out. Even when I have to pull the distributor again it should stay.
I know, I know...PULL THE PAN! Well, I'm not going to do it the right way. I'm going to do it the "livin in southern OHIO, my family is from KY, ain't no way I'm going to make that oil pan leak, laying on my back, workin' in the gravel even when it's snowing and raining" way.
Wish me luck and thanks for your support.
pb_paulie_b
894
Chaptico, Maryland
Nov 14, 2005
  • Nov 14, 2005
when i bought my mustang there was no clip installed on my oil-pump shaft. one day i pulled my dist. and the shaft stuck in the bottom of the dist. and fell onto my motor. long story short it happened to me an......WHAT A PAIN IN MY AZZ!!!!!! puttin it in from the top is some half-assed shiite...PB
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Nov 14, 2005
#10
  • Nov 14, 2005
  • #10
well i just went throguh the problem of the oil pump shaft. the person before me put the thing in form the top like ur goin to do and when i pulled the dizzy and it ended up causing me a big pain in the ass when i couldnt figure out y the car had no oil press when i cranked it back. SAVE urself the troble and install it the right way!!
EDIT: i did some other stuff beside pull the dizzy. Thats y it was a pain in the ass to figure out!!
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
  • dan50
  • Jul 18, 2026
dan50
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
