oil pump
The best way I can think of would require some work. I would hook a mechanical gauge into the oil port (just in front of the oil filter). It would be kinda hard to get to with the motor in the car, and you would have to remove the oil sending unit. Then I would remove the distributor, get an electric drill, put a long extension on it with a small OD 1/4" deep well socket, and start cranking it (counter clockwise I believe). Just watch the gauge for pressure, depending on how fast your drill is turning (it will take a strong one) you should have at least 20psi I would say, my car as around 50 when it's running but drops to around 10-15 if it starts to idle too low (600-700).
Good advice from Jason. Just be sure if you use a 1/4" socket, that it is SECURED to the extension. Don't want that thing falling off inside your engine. Are you making no oil pressure, or just low oil pressure? Typically if a pump goes bad, it just locks up; I don't think they just start making 'less pressure'.
O.K. well I do know this much its a high volume oil pump thats in there right now. Its what was in there when I bought the car back in NOV. When I was putting my motor back in last month I crushed the oil pan a little bit nothing that I think is super major. Is there a chance that I damaged the pick up tube when I did this and that it has finally acted up and its been my problem all along with the lifters being noisy even though until yestarday I had no oil pressure problems at all. As a matter of fact at hywy speeds my pressure until yestarday was holding at 70psi and at idle 40. I have been told that the high volume pumps cause problems and that all that motor needs is a standard pump. I only have 600 miles on this motor since I had it rebuilt. Also is it necessary to pull the motor in order to change the pump?
