my 95 has 125k and it leaks oil a fair amount. i'm using 10W40 right now. if i switched to 20W50 would that potentially slow the leak? according to my stock guage, the pressure is fine, i just leak from probably the rear main.
but wouldn't that mean that 10W40 now would flow like an even lighter weight oil in the summer thus leaking more?HISSIN50 said:Look at it this way - if you need 20-50 now, what will you do in the summer when 20-50 flows like 10-40 now?
Good luck.
Yes, thats exactly what he means...90bronconate said:but wouldn't that mean that 10W40 now would flow like an even lighter weight oil in the summer thus leaking more?
Yes, 10W-40 right now probably flows about like 20W-50 does in 115*F ambient temps (I am down in Tucson).90bronconate said:but wouldn't that mean that 10W40 now would flow like an even lighter weight oil in the summer thus leaking more?
right. i'm going to try and clean everything really good this weekend to see where the leak is coming from and that is what i'll try first. if that fails then i get to tear into it.8950HO said:Before replacing the rear main seal,make sure your PCV system is not plugged up.Take out the PCV valve and the rubber grommet the valve sits in the fish out the breather element screen and see if it`s plugged up.
Clean the breather element in acetone or buy a new one.
If that screen is plugged up,it can cause a perfectly good rear main seal to leak due to excessive crankcase pressure buildup.
