  • 1994 - 1995 Specific Tech
Oil/seal issues...please help
  • Thread starter Thread starter NotQuik
  • Start date Start date Jun 17, 2007
NotQuik
5,158
29
88
Central Florida
Jun 17, 2007
  • Jun 17, 2007
Alright, bought car had AODE, always had oil leak from day one....removed trans and replaced with tremec and changed rear main at same time, still leaked. Throw out bearing failed removed trans replaced clutch (smoked it) replaced rear main again, still leaked...drove for awhile front main now leaking too (harmonic balancer went bad) removed trans again replaced rear main (Just to make sure I wasn't losing it or doing it wrong, Mechanic friend of mine did it and no scaring on crank whatsoever to just get that out) also replaced oil pan gasket this time around as well, and frpp sfi harmonic balancer too, still leaking at front and rear main. I still have vibrations I can feel as car revs up....i'm thinking is it possible for main bearing to go bad and cause play in the crank and in turn cause my vibrations/leak issues? Any help or suggestions would be great.
Motor is stock BTW, and has about 124k miles if that's good for anything and wasn't well cared for before I bought it.
StinkinLincoln
240
Louisiana
Jun 17, 2007
  • Jun 17, 2007
yeah the vibrations can mess up the crank, bearings and the internal parts. best thing to do is rebuild and maby invest in a stroker kit...
NotQuik
5,158
29
88
Central Florida
Jun 20, 2007
  • Jun 20, 2007
Thank you, that is what I was looking to hear....just wanted to make sure I was on the right track.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
