Hi guys wanted to know, where do you mount the aftermarket oil pressure sender, it seems so big, and I wanted to keep my stock gauge too.
where did you mount yours ??
IIRC I used a 3 in pipe, then a 90* elbow, pointed it downwards, then put a T on it with the stock sensor pointing down, and the aftermarket one positioned by the filter.
I got the long fitting that comes on a 87-93.The stock sending unit screws in the end and you have about three inches of room to drill and tap for your aftermarket sending unit,blower feed,etc.
ok got the sender is working how much is it suppose to read anyway at idle ??
I have these 2 autometer gauges but neither of them seem to be working right
the temp meter starts climbing and it never stops, and the autometer oil gauge is only showing about 30psi while the stock gauge is showing like 55 psi..
iv'e tried to take ground from different places wouldn't make any difference, now the 12 volt source is coming from the radio is this wrong ??
Put a jumper ground on the sender's body and see if your reading changes. A ground path is achieved through the sender body (and the engine) but if lots of teflon tape is used, that can hinder the ground path.
