  • SN95 4.6L Mustang Tech
Oil Separator Installed..full..help!!!
  • Thread starter Thread starter 98stangv8
  • Start date Start date Nov 18, 2005
1 of 2 Next Last
98stangv8
1,036
fayetteville, nc
Nov 18, 2005
  • Nov 18, 2005
ok...I am relieved and freaked out right now...I just installed my oil separator...I took a, literally, 5 mile drive..and by the time I got back, the thing was almost full....why is there that much oil going into it? Did I overfill my oil? I checked the dipstick, and it looked fine..what would cause this?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 18, 2005
  • Nov 18, 2005
where did you install the hoses at did you put it on the pass side valve cover where the pcv is at and the other at the plenum..
98stangv8
1,036
fayetteville, nc
Nov 18, 2005
  • Nov 18, 2005
yep..exactly...ran it from the pass valve cover, to the separator, to the bottom of the plenum...does the length of the hose make any difference or anything? I mounted it right beside the maf....not on the back of the firewall...I didn't think that would do anything though??
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 18, 2005
  • Nov 18, 2005
that sounds about right hmmmm.... i cant think of anything that would make it fill up quick other than their is something wrong either with the pcv do you have pics of your setup?
98stangv8
1,036
fayetteville, nc
Nov 18, 2005
  • Nov 18, 2005
oil separator setup? what does the pcv do? is that the part that actually plugs into the valve cover?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 18, 2005
  • Nov 18, 2005
yeah that what it is it goes into the pass side valve cover
sgarlic
3,085
Nov 18, 2005
  • Nov 18, 2005
Probably just have a lot of blowby. It's probably just your engine and everything.. I wouldn't worry about it unless you start smoking out the tailpipes or something. My '04 with 7k miles fills it over halfway in a week or so of driving. Just be happy it's going in to the separator and not the intake.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 18, 2005
  • Nov 18, 2005
oh yeah i forgot did you install the separator its self right they are directional they have a arrow of flow the arrow ahould point to the plenum
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 18, 2005
  • Nov 18, 2005
But... five miles and its full? That can't be right
sgarlic
3,085
Nov 18, 2005
#10
  • Nov 18, 2005
  • #10
Yeah I wouldn't think it should be totally full after 5 miles. That sounds like an awful lot of blowby. Like somebody said earlier, I'd check your PCV valve to make sure it's working right.. give a shake and see if it rattles. If not, try replacing it. The placement of the hoses, or the separator shouldn't make any difference in how much it collects.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 18, 2005
#11
  • Nov 18, 2005
  • #11
he should also check the separator its self and is pointing at the directionof flow or that could also make it fill up fast
98stangv8
1,036
fayetteville, nc
Nov 18, 2005
#12
  • Nov 18, 2005
  • #12
yep...the arrow direction is good to go...
what exactly does the pcv do?
hotmustang331
2,967
Bastrop,TX
Nov 18, 2005
#13
  • Nov 18, 2005
  • #13
Shoot, I go a good 500 miles and have LESS than a 1/4 in there . Mine is tied into BOTH pcv systems, and I deleted my line into the CAI and rerouted it (using a T) into my other PCV line, then through my oil seperator and into my intake manilfold. So every bit of the PCV system goes through the seperator.
Took me a month or 2 to figure out I had 2 PCV lines, because all I was getting was a thin film in the holder and no liquid lol.
hotmustang331
2,967
Bastrop,TX
Nov 18, 2005
#14
  • Nov 18, 2005
  • #14
What it does, is suck any excess oil out of the valve cover and burns it through the engine. It also pulls any pressure out of the crank case..DONT PLUG THE PCV SYSTEM BTW. Some compression leaks into the crank case, and the pressure needs to be releaved.
C
Chopper1
91
Wv
Nov 19, 2005
#15
  • Nov 19, 2005
  • #15
The other,drivers side,of the PCV system is to allow filtered air into the engine to allow the passenger side part to pull contaminated air from the crankcase.
98stangv8
1,036
fayetteville, nc
Nov 19, 2005
#16
  • Nov 19, 2005
  • #16
does it hurt anything if the oil goes into the intake and gets burned?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 19, 2005
#17
  • Nov 19, 2005
  • #17
it will in the long run by building up behind the valves and causing them not seal right
Venom_Nitrous
416
Spearfish, SD
Nov 19, 2005
#18
  • Nov 19, 2005
  • #18
It may be mounted to low relevent to the PCV and actually siphon it out. That would be my only guess.
jivepepper
776
Under a Sombrero. in WV.
Nov 19, 2005
#19
  • Nov 19, 2005
  • #19
Thats way to much blow by. I know you have a forged engine but to me it sounds like a bust ring or ringland. Do a conpression and or leak down test.
98stangv8
1,036
fayetteville, nc
Nov 19, 2005
#20
  • Nov 19, 2005
  • #20
how do I do those? could it just be a bad pcv valve? Should I just get a new one and try that? the one in there now is really loose...it comes out way too easily...could that be causing it?
1 of 2 Next Last
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
