Ok, I did the search and even thought I knew the answer..alternator wires?
I'm looking into that same cable as well.
PA Performance has a great quality 4 guage cable w/200 amp fuse built in for our cars. Length is perfect too. However, you'll have to either keep your stock double connector thing in place OR use the one you put a link to. Just haven't confirmed either if anyone has done so with the exact wire you mentioned.
I need to take a look at both ends of the connection, cause I'm not sure if the non-alternator connection at the fuse box is the same as that shown in the picture. My connectors are real old and fragile looking, so this would be good to replace.
I like to think I'm semi-intelligent with alternator wiring but I'm not sure what you're asking.
If you want a new regulator plug and some wire (in case your old wire is vulcanized - mine was), that LRS plug only has two wires, right? It seems to me we have 3. I wonder if they got tricky with their stator hook-up. I'd call and ask for confirmation if you go that route.
Here's a cool harness. You should only have to connect one regulator wire to the original car harness (the stator and A terminal wires each get looped - neat!). You would want to make or buy a new charge cable too. I made mine for about 15 bucks. This is a pretty slick way to do things.
Good luck.
Would that 2 wire kit replace the wiring harness from the fuse box in the engine compartment?
I think my Alternator harness is vulcanized, when the car heats up, the Amps drop quite a bit.
Replaced Alternator and removed underdrive pulleys, and the Amps still drop after the car heats up.
Any ideas?
Any ideas?
It's actually the little wires in the regulator harness that vulcanize (when I peeled the wire sheath off - it didn't actually peel but flew off in hard chunks), the insulation on my wires was gone :eek: ). I used what I thought was a 3 wire plug from LRS and spliced it in.
The charge cables just like to fall apart. They get weak at the terminal and start to fray.
A quick test for you to do: On a cold engine start it up and wait for the idle to stabilize. Put your DMM across the battery. Note the voltage. Now move to the alternator's charge lug and put your meter lead on it, and touch the ground lead to either a real clean ground (or better) the negative battery terminal. See if there's a notable difference in voltage. As an E.g., my OEM charge cable was dropping 400 mA. That's on the edge of acceptable but not to us! The new cable drops about 2 mA (average due to meter fluctuation of around 5 mA up and down). Much better.
For your situation, I'd want to see what your idle is like. If it falls much below 650 RPM, alt output takes a dump. If you can goose the gas pedal a little bit (bring RPM's up to around 7-800 RPM) and the alt output gets much better, you can either raise the idle or consider overdriving your alternator. If you do the latter, try to ensure you will not spin the alt over it's critical speed (for most 3G's, that figure is 15000 RPM).
As for the regulator plugs and wiring, I think you guys will be hard-pressed to find anything that is 'full length'. That's certainly not to say that you can't make your own full-length harness.
Good luck.
