  • SN95 4.6L Mustang Tech
ok Im stumped
  • Thread starter Thread starter usaf_branham
  • Start date Start date Apr 28, 2011
usaf_branham
927
134
84
Boston
Apr 28, 2011
  • Apr 28, 2011
Ok... I have a new clutch (ram powergrip), new ford racing tob, new ford racing pilot bearing... I have a firewall adjuster, billet quadrant, and im using the stock clutch cable... everything works as advertised... clutch is 1000% better than stock for my application, the firewall adjuster moves engagement from the bottom of the pedal to the top (which is set up and has been setup in the stock release location)... everything seems to be in perfect working order as it is supposed to be, except...
when the clutch pedal is fully released, the throwout bearing is screaming like hell. if i apply just the slightest bit of pressure to the clutch pedal it stops. it does this in every gear and neutral. ive tried backing the adjustment out, ive tried raising the adjustment. ive even tried spraying the tob itself with lube while the engine is running to get it to stop and NOTHING is working. Im debating on putting a light duty spring on either the quadrant or the fork to apply the 1/2 lb of pressure to the tob, to get it to quit squeeling. but before i do that, i would like to know what your guys take is on this.
note: its got about 1/4 inch of slack in the cable right now and even when i take the slack out, it still squeels. it only stops when i apply light pressure to the pedal.
please help.
usaf_branham
927
134
84
Boston
Apr 28, 2011
  • Apr 28, 2011
one more thing...
if i adjust the clutch out to the point where it does quit squeeling, (which can be done), the clutch is so high that its borderline slipping (i think), and i know that there has to be alot of pressure on the TOB at that point which can lead to premature failure. the strange thing is, if i adjust it to the point where its catching literally off the floor, it still does the same thing. squeels until i put very light pressure on the pedal.
this makes no sense to me at all.
txstang84
1,639
42
69
Tuscola, tx
Apr 28, 2011
  • Apr 28, 2011
I've never lubed a throwout bearing-I wouldn't recommend it to anyone either. That being said, when you received the bearing, did it have lube in it? When you spun it, was there perceptible "drag" like a freshly greased wheel bearing? Or was it super easy to spin and just whizzed away? Please excuse me if I'm coming off as condescending-I assure you it's not the intent...we just swapped the engine in a buddy's car and his bearing sounded like absolute poo until he put some pressure on the pedal...it was dry as could be. Might've gotten a dry bearing?
txstang84
1,639
42
69
Tuscola, tx
Apr 28, 2011
  • Apr 28, 2011
FWIW, when I threw a new KC in my '84, the pedal engaged about 2" off the floor for the first couple hundred miles...after that, it started to normalize about 2" from top of travel...
usaf_branham
927
134
84
Boston
Apr 29, 2011
  • Apr 29, 2011
the tob was greased, it had drag. i did have to re-adjust the clutch after a few hundread miles. as for lubing the bearing, i was reaching for straws. i used the same stuff i use on my s/c idler pulleys and hoped it would help in that situation as well. maybe it has something to do with the clutch cable? i dunno. it doesnt make any sense to me. but im tired of driving around town with my foot lightly pressing the clutch so it doesnt squeel.
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
