When I did the engine swap I converted to all fox throttle body parts. Since the car has the exact same behavior now as it did before the swap I can rule out the IAC and any of the parts associated with the Tbody swap.
Before the swap though, I could leave the car sitting in the yard idling and it would start hunting on it's own and eventually die. It would do this in drive throughs which was very annoying. The problem was cured with the new setup.
Cold start-ups are fine for the most parts. Except for instance, if I pull the car to the back yard to work on it right after a cold start, it will hunt and die upon upon stopping. So I have to ease the gas pedal a little bit to compensate. What is seams like here is the computer is letting the RPM's fall way too low when the car comes to a stop then it tries to over compensate high, the overcompensates too low which results in a stall.
In the fox's I've owned, as I come to a stop, the RPM's don't just fall to idle instantly, it kinds tapers down gradually over a couple seconds from around 1000 rpms down to idle. That's what this car should do. And yes, my car seems to do it more severely with the A/C on.
