i just finished dropping the 4.6 2v (01') into my car. I also have the saleen routes type supercharger bolted on with the heat exchange ... The trans is out of a 99 cobra with a dual friction centerforce clutch. The car is up and running well... EXCEPT..... I have a small problem. The car revs well and runs well when not in gear. I can push the pedal to the ground and get a smooth acceleration of the motor. Well when the engine is in gear for example first... it does not do that. The engine hesitates or studders from idle to about 2700 - 3000 rpm. It's odd because this is only when the car is in gear. I thought that it would do it all the time. Well what the car does is hesistate and run rough through those rpm. It has trouble moving through those rpm and when it get out of them.. it revs a lot cleaner. I'm not sure if the engine is running too rich or too lean. My guess is too lean because of the supercharger. Also to add to this incase someone has an idea what is going wrong... I do not have the pvc or egr system... they are blocked off. Well I bought a computer from someone that was supposevely from a 99 saleen s281.. it had the saleen factory sticker and information. Anyone have an idea what is going wrong? or better yet.. how to fix the problem. please help
Eric
Eric
