Hi, I am looking at a set of used Trick flow twisted heads.
Will there be a piston / Valve clearance problem if I run stock flat tops w/ valve reliefs? The heads have 202 and 160 valves 60cc combustion chambers.
the cam will be a ford F303 512 lift. And I will be using MLS head gaskets.
Engine will be a 5.0
Should I be concerned about clearance problems?
Thanks
Thanks
