Ok well I was changing the fluid in my trans as I have done millions of times before and on plenty of T5's. Well for some reason this time I am tightening the drain plug, I barely felt it tight at all and I hear.... Crack...
... So now I have a very annoying leak from that crack that I tried to cover up with quicksteel and it turned it into a few drops under the car after sitting for a week. But still drives me nuts that its like that. Ok well here is my question. Any suggestions on how to fix this? I talked to the machine shop we use at the dealer and they told me they could weld it and use some kind special insert so that it wouldnt leak. The insert only is $120 plus w/e they want to charge for welding the case. And I have to gut the case before he can do it. I am also going to try calling this trans shop were I get all my trans parts from and see if they may have any better Ideas or maybe even if they have a new case. But I wont be working at the dealer much longer so I am trying to get everything done I need to get done to the car before I start at the new job. I was also thinking maybe upgrading to a t56. Anyone have any suggestions about what to do and what is involved in a t56 swap? Thanks in advance.
