old alarm
  • Thread starter Thread starter dkins419
  • Start date Start date Jul 30, 2005
dkins419
187
Michigan
Jul 30, 2005
  • Jul 30, 2005
well i took the dash out today well not really i cant figure out whats still holding it on the drivers side so its almost out. So i look under there and theres an old alarm that doesnt even look hooked up rite and when i look at it its just a nightmare. Im scared to try and take it out because im not sure if i can find everything that it originally would connect to. The reason im taking the dash is out to install an alarm. Anyone have any wiring diagrams or anything to help me? Im gonna look it over tomorrow again and decide if i can see whats what.
HISSIN50
34
129
Jul 30, 2005
  • Jul 30, 2005
Most alarm wires splice into existing wires - they are not in series (starter interlock and power locks are exceptions).
You might be able to save some work if that alarm has a wire chart on its body. You can quickly test and reuse existing wires on your new alarm.
People will need to know the year of your car in order to help with wiring diagrams.
Good luck.
dkins419
187
Michigan
Jul 30, 2005
  • Jul 30, 2005
thanks for the reply. Its a 88 GT.
HISSIN50
34
129
Jul 30, 2005
  • Jul 30, 2005
Did you get an install sheet with the alarm (telling you wire colors and locations to use for your 88)? Is that what you are desiring?
And with removing the old harness, I just take it a wire/connection at a time. Like I said, if the wire from the alarm harness "Tee's" into an OEM wire, one can remove the alarm wire with no issues. If you see a cut wire and alarm wires in series (like is the case with most starter kills) then you want to reconnect the wire (or immediately install your starter kill relay on your new alarm. most alarms have the relay installed passively so you dont need the alarm to work to start the car - you need the alarm to work to have the starter disable actually disable the car).
Good luck.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
