I'll make this brief
all parking lights are bright
hazards are bright
when low AND high beams on=passenger side lights become dim (headlight, & 2 parking lights)??? running about 50% power
This is my protocol tonight:
check ground on pass side light
replace passenger bulb (process of elimination)
replace #4 fuse IN CAR to make sure its good
Check all connectors for corrosion
QUESTION:
Are there any in-line fuses in the engine bay for the lights that I need to check?
From the research I have done, it HAS TO BE
-fuse
-grounds
-bulb
-corrosion on wires/ connectors
Set me up for success fellas, am I missing any other things to check?
Thanks!
hazards are bright
QUESTION:
-fuse
-grounds
-bulb
Thanks!
