Hi all,
First timer here. My gf bought halo/led headlights for her 04 mustang and I wanted to surprise her by putting them in while she's gone for a few days. I prepared the new headlight wiring exactly like the instructional video said. I then went out and disassembled the old headlights...then I tested the headlight connector to see which of the two wires contains power. Unfortunately, because I've never used a voltmeter before, I had it on the wrong setting and when I touched the lead to the connector, it sparked and now the headlight connector doesn't work. The turn signal on the same side does work, but I'm not sure if it's wired into to something else. After putting the voltmeter on the correct setting, I went back and tried to test the connector again. One connection does show a little bit more power than the other, but it's still only at like a 4... Could I have shorted out the connector and not the wires?
I checked the fuses under the hood and near the drivers side panel. None were popped and I replaced the ones that deal with the headlights just to be sure. Still doesn't work. I'm thinking I shorted out the wire and now need to fix it. Does anyone know of an instructional video of how to do it...or seeing as how I got into this mess to begin with, do I need to take it to a mechanic to be fixed?
Thank you in advance for any help you might be able to provide me with!
