One side smokes other doesn't?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Jan 4, 2008
TrickFlowd
240
Sayre, PA
Jan 4, 2008
  • Jan 4, 2008
It was super cold out the other day...so I started the stang and let it run for about 10 mins. While idling, there was steam coming out of left side exhaust and not the other. If i revved on it a little both would puff equally. Is this normal at an idle with an aftermarket cam? The car idles pretty rough.
Maryland Stang
1,656
30
39
Greenville, NC
Jan 5, 2008
  • Jan 5, 2008
As long as you don't have that problem when it's warmed up there's nothing to worry about. If you drive the car for 20 minutes and it's still doing it then look for an antifreeze leak.
It's just that one side of the exhaust picked up a little more moisture than the other. The cam has nothing to do with it.
fastford91
254
Niagara ,Ontario, Canada
Jan 5, 2008
  • Jan 5, 2008
hes from New York! same weather as i get here! its normal!!! its called cold weather! and you will have white smoke coming out the tails all the time if it super cold out like it has been here lately! -23 the other night! unless it smells sweet ( which would indicate an antifreeze leak ) or its excessive!!!! i mean a lot!! you dont have anything to worry about! being from New York and getting the weather we have have you ever seen this coming from the other cars on the road? you dont see it so much when the car is in motion unless its just been started! you will get a lot! but you see it more when stopped at a light and waiting! when the weather is as cold as it has been! James
TrickFlowd
240
Sayre, PA
Jan 5, 2008
  • Jan 5, 2008
I know the car will smoke steam when its cold out. I was just worried about one side puffing and the other doing nothing, like a dead cylinder...but the car ran perfect so I won't worry about it. Thanks guys!
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
