  • 1994 - 1995 Specific Tech
one thing after another....
  • Thread starter Thread starter snakedoc98
  • Start date Start date Jan 9, 2011
snakedoc98
30
oceanside, CA
Jan 9, 2011
  • Jan 9, 2011
Alright guys, my car sat in storage for 7 months while I was deployed. I did all the storage stuff to it like full tank with stable, bag on tail pipes, intake etc. I got it out of storage and on my way home I got a code 118, ect sensor signal voltage is too high. So I went ahead and replaced the engine coolant temp sensor and while doing that I notice the water pump, radiator were leaking so I replaced the whole cooling system. Well I started the car up and it had a really rough idle. so I figured it was from sitting for about a month while I got all the parts for the coolant system. So I took the car around the block and got a cel with two new codes, 172 oxygen sensor voltage signal indicates lean bank 1 and code 543 fuel pump circuit open connection, electronic control assembly to battery. When the car idles like at a stop light the idle surges. I checked the timing, set at 12 degrees. I'm just not sure to go with this one guys.
hollywoodstang
1,095
Jan 10, 2011
  • Jan 10, 2011
May be your o2 sensors went out, When my car's o2 went out, it ran like crap and threw all kinds of cel #'s
Not sure about your fuel issue, May be you should clean out the fuel system. May be send out your injectors to get it cleaned etc etc
Good luck man
HISSIN50
34
129
Jan 10, 2011
  • Jan 10, 2011
Was the car up to temp when you ran codes the first time? If not, you can toss the ECT code (the EEC expects the coolant to be at 170+ when you run codes).
You could swap the O2's and see if the code follows that particular O2.
Is it still running rough?
snakedoc98
30
oceanside, CA
Jan 10, 2011
  • Jan 10, 2011
Yes, it was up to full temp. Weird thing tho, after upgrading my cooling system the temp gauge only goes up to the line right before the N. I know it is getting up to temp for two reasons. The fan turns on and and I took a temp gauge and pointed it at the thermostat and watched the temp go up and down as it opened and closed. As far as the o2's go I thought that if they go bad they would send a rich code not a lean? thank you guys
alleymad95GT
204
Okemos, Michigan
Jan 10, 2011
  • Jan 10, 2011
When the O2s fail, they indicate lean. Actually, from a design standpoint, this makes sense because the computer response to a lean condition is to add fuel, and you would rather the computer add fuel when it didn't need to (in response to a failing O2 indicating lean) than pull fuel. Better to run rich than lean, right?
snakedoc98
30
oceanside, CA
Jan 10, 2011
  • Jan 10, 2011
alright guys, now I have no cel but the car will surge were it will have no power then tons of it then bog down. It has died on me twice at idle.
hollywoodstang
1,095
Jan 11, 2011
  • Jan 11, 2011
I am starting to think this is EGR valve related issue, may be others can get in here and figure this out
snakedoc98
30
oceanside, CA
Jan 11, 2011
  • Jan 11, 2011
well as of last night the car has new o2s and still having the same issue. I am going to test the egr on the car tonight and see what I come up with.
hollywoodstang
1,095
Jan 12, 2011
  • Jan 12, 2011
So was it EGR? What was/is the problem? Also if you have off-road X/H pipe, It will burn your o2 lot faster, IT seems like i am replacing mine every year or year and a half...
snakedoc98
30
oceanside, CA
Jan 15, 2011
#10
  • Jan 15, 2011
  • #10
alright guys, so the car has new o2's and last night a new egr and gasket. I unhooked the battery and left it all last night. This morning I hooked the battery back up and took it for about a 60 mile round trip drive. Well the car know seems to have no power at low rpms and still has a rough idle but wont die. I checked the codes and I am still getting code 543 fuel pump circuit open connection, electronic control assembly to battery.
snakedoc98
30
oceanside, CA
Jan 15, 2011
#11
  • Jan 15, 2011
  • #11
I'm loosing my mind! I just reset the computer and took the car for a drive. Same thing no cel but when I got it home and scanned the codes I got a new code 542 fuel pump circuit open connection, electronic control assembly to motor ground. Please someone chime in.
1987LXragtop
837
Just outside Philly PA
Jan 15, 2011
#12
  • Jan 15, 2011
  • #12
Any chance of a wiring harness issue? Seems like you change one thing another pops up some where else. I knew someone who stored a camaro for a bit a critter got in at the harness.
Just a thought
hollywoodstang
1,095
Jan 15, 2011
#13
  • Jan 15, 2011
  • #13
May be your ccrm is going out, Did you change the fuel pump and fuel filter lately? how old is your pump?
I hope you get this fixed soon
snakedoc98
30
oceanside, CA
Jan 15, 2011
#14
  • Jan 15, 2011
  • #14
I have no idea how old the pump is but the filter is newer. I'm starting to think its the ccrm too. tomorrow I'm going to get the multimeter out and start shooting wires. Thanks for all the help.
R
rangr50
#15
  • Jan 24, 2011
  • #15
Hey, guys, new here, but not new to Mustangs (86 GT and 94 GT engine in a Ranger). Seems I'm in a very similar situation. I'm going to keep an eye on this thread to see where it leads. I'm going to throw my similar situation out there, which may or may not be of help. It's going to be long, but thorough.
I have a 94 Mustang 5.0 in my Ranger. I have been having an issue that has continually gotten worse and I'm at my wits end to figure out what is going on. The engine is a stock engine with wiring harness, computer, etc from the Mustang. When cold the engine starts up and idles well. Going down the quarter mile driveway it seems fine and then upon acceleration it acts like I just pulled the choke on. It bogs down, has no power, occasionally backfires out of the intake. Then, for no reason it will just start running great with full power. I initially pulled an O2 sensor code and a 542 (fuel pump circuit). I'm not sure what the fuel pump circuit is supposed to mean. I have a low pressure and a high pressure pump and both are working well. I can check fuel pressure even during the low power issue while accelerating going down the driveway and it stays around 40 psi. So, I would like to think that I could rule out the fuel system. Now, the thing I don't understand is that when initially trying to pull codes I could not get the code scanner to work. When I plugged it in and turned the key on it would just beep in the hold position. When flipped to test it would do nothing but continue to beep. I ended up messing with the wires at the connection to the computer and found that if I wiggled a certain wire it would stop beeping, but if I touched another wire it would start back up. That certain wire was for the O2 sensor. So, I disconnected the O2 sensor harness from the injector harness and I could now use the tester. Figuring there was a problem with the O2 sensor harness, which I made myself 6 years ago (solder/heat shrink high quality job), I pulled it out and tested for continuity through all the wires (along with a visual inspection). I could not find anything causing a short. So, with the O2 sensors disconnected I reconnected the O2 harness to the injector harness and again could not pull codes. Figuring there was something wrong with the connection there I eliminated it and hard wired the O2 harness to the injector harness. Well, that just made things worse because I can not pull codes at all now.
Similar to the situation above it will occasionally go into self test mode without the scanner (idles between 1400 and 1800 on its own for a short period of time before going back to normal).
When this problem started I could let the truck warm up and then it would run fine. Now, it seems that it will barely allow me to drive it even with it warm.
I have already swapped the computer to verify that's not the problem.
Any ideas on this would be great. I hope we can solve both our problems.
Brian
KamiKaziDK
555
Mesa, Az
Jan 25, 2011
#16
  • Jan 25, 2011
  • #16
I'd say wait for Hissin or Richter to chime in, they're pretty much the gurus in this dept. I'm pretty sure you'll get that code if the fuel pressure drops out of good range, so it might be your fuel pump is going out on you, that wouldn't be surprising as the car has sat for a while. Smell your gas for one, but just cause it's good, doesn't mean that your pump is still fine.... If you have access to a tool, test your fuel pressure. I have a full sweep autometer gauge on my car because I've had such horrible luck with pumps for some reason.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sunday at 2:52 PM
JohnKay
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
