  • SN95 V6 Mustang Tech
Opaque/sun-beaten headlights
  • Thread starter Thread starter susheelover
  • Start date Start date Jul 26, 2007
susheelover
17
  • Jul 26, 2007
What's up? I tried to search for this topic in old threads, but found none. My 2001 V-6 has headlights that are opaque and look like they are poc-marked and old, like the sun has damaged them, making them crack slightly. I bought it used in 2003, and it was like that already. I am thinking about getting the Black Angel-eye headlights to replace them, but I was wondering if anyone knows a way to polish them back to the factory look
My cyclops light was like that too, sun-damaged and ugly, but it was the first thing I replaced. I see so many other Mustangs with this problem, I am sure you know what I am talking about, even if I did not describe it right. help...
p.s. You can sort of see in the pics in My Garage.....
Skymarshal
572
Dallas
Jul 27, 2007
  • Jul 27, 2007
Polishing them is tough, but can be done. You need to look for a headlight polishing kit that's sold in the car parts stores that includes several sheets of fine grit abrasive paper and a tube of polish. If you can't find that, you can get your own abrasive (1200, 2000, and 4000 grit if I remember) and use some of the plastic compound that is available in the abrasives section at Home Depot or Lowe's. You'll need a buff on a grinder or polisher, since a lot of elbow grease is required.
It's a lot of work, so a lot of people just buy another set of headlights. Make sure they're DOT stamped so you're not blinding people and getting pulled over all the time!
cervinistang
11
Dearborn, Michigan
Jul 27, 2007
  • Jul 27, 2007
start with 500 if it is bad, then move to 2000+. wet sand.
wipe some toothpaste around wash off. Buff on Meguires PlasticX or whatever till it gets shiny. If your still yellow Put rubbing alchol into the lights and shake them around with your hand cuping the light holes. Or tape over them. DONT USE WATER! the alchol will burn off some yellow grit on the inside and wont make them fog up like water.
susheelover
17
  • Jul 28, 2007
Thanks guys...I don't a have yellowing problem...just hard to see if my lights are actually on at night ...yikes! The opaqueness diffuses the lights..gonna do something soon.
Thanks again!
95&Modified
  • Jul 28, 2007
It was easy
Mine sucked on my 97 when I first got it last year. But while in WallyWorld I came upon a kit to clean/buff them and it worked like a charm. It didn't take long at all with my drill. In the kit you have these sticky pads with some kind of white stuff on them that you stick to a rubber pad and you put on your drill. A little water and a little time and they look much better than before. I cannot remember the name but it was a black box about 3 inches square and 6 deep in size with different colored writng on it.
susheelover
17
  • Aug 2, 2007
Hey Modified,
Which auto parts store did you buy it from?
susheelover
17
  • Aug 2, 2007
Found it!
http://www.lensrenew.com/order.htm
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
M
  • Locked
2001 evap core tube support
  • mnky99
  • Sep 4, 2025
SN95 V6 Mustang Tech Sep 5, 2025
mnky99
M
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
