Opening up BBK longtube collector
  • Thread starter Thread starter Grn92LX
  • Start date Start date Oct 12, 2005
First Prev 2 of 2
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 14, 2005
#21
  • Oct 14, 2005
  • #21
What was his n/a 331 combo? Are you saying he didn't swap to the correct valve spring for his camshaft? Thats a big no-no!
04sleeper
2,674
14
89
Dallas, TX
Oct 14, 2005
#22
  • Oct 14, 2005
  • #22
331 with 10.5-1. AFR 185's, Ported Holley Intake, Accufab 75 MM TB, 42 lb. injectors, Cam Motions Custom Cam, Pro-M 80, Custom power pipe, etc....
He did switch to new springs but the cam was too radical of a profile to run on the street and put a lot of miles on. It was a grind for True Street.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 14, 2005
#23
  • Oct 14, 2005
  • #23
Sleeper, do you happen to have access to your friends dyno sheet showing the before and after gains of the 3" collector vs stock collector? I wanna see where the gains were and if it was through out the entire curve. Thanks pal.
Looks like this thread is very informative!
dirtysohc
103
High Point N.C.
Oct 14, 2005
#24
  • Oct 14, 2005
  • #24
I would've guessed 5 to 10 HP, but 15 is even better! And all for just a few minutes of grinding! My headers have been sitting under my hood for years (engine in the garage) and have become rusty. They were chrome not ceramic so they've gotten nasty lookin'. But I'm taking them and the Dr. Gas X-Pipe to a local coating place to have them jet hotted soon.
vristang
4,933
101
124
Seattle
Oct 14, 2005
#25
  • Oct 14, 2005
  • #25
I know I am coming in late, but I have done this with my MAC headers, and wanted to offer a caution.
Do not do this without mocking things up first. My mac headers and prochamber midpipe do not quite match up perfectly. The mid pipe mates up to the header flange at an angle. If I had just started grinding as was done in the pictures that dirtysohc provided, I would have had massive exhaust leaks. If you run the exhaust for a while you will build up some carbon deposits on all the parts of the header flange that does not make contact with the midpipe. You can safely grind all of this material away. If anything in the exhaust changes however you may lose the seal.
Best of luck,
jason
dirtysohc
103
High Point N.C.
Oct 14, 2005
#26
  • Oct 14, 2005
  • #26
Good point vristang. ALWAYS mock it up first to see how much you should actually grind away or you could ruin it or at the very least cause a bad seal. I was lucky in the fact that my Dr. Gas X-Pipe came in pieces and the first length of pipe after the header flange is a straight shot. After mocking it up I then fit the pieces together under the car, tack welded it and then removed it for complete welding. But if the x or h pipe is pre-made you may not be able to grind as much away. Better safe than sorry.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 18, 2005
#27
  • Oct 18, 2005
  • #27
89sleeper said:
When my friend did this his car was N/A. It made 395 RWHP before switching the collectors and 410 RWHP after switching. Now that he has a blower, I'm sure the gains would have been more.
When he swapped to the 3" collector did he swap to a 3" mid pipe too? Im assumming the 15hp was a collector and 3" mid pipe swap from the 2.5" mid pipe?
Do you happen to have access to his before/after dyno sheets after the swap? I know you said he gained 15hp but i'd like to see the gains through out if possible
Mike
04sleeper
2,674
14
89
Dallas, TX
Oct 18, 2005
#28
  • Oct 18, 2005
  • #28
Mike
Actually he had a 2.5" mid pipe and 2.5" Dynomax Super Turbo mufflers and tails. He probably could have made more power with different mufflers but he wanted to try to keep it quiet.
I will ask him if he can scan his sheets for me.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 19, 2005
#29
  • Oct 19, 2005
  • #29
Wow so all he did was swap to a 3" collector and modified the 2.5" H pipe to work? If you can get those dyno sheet's that'd be great!
Hopefully I can see a decent gain by opening up the collector and swapping to a 3" mid pipe.
Vapors
39
Bakersfield
Oct 19, 2005
#30
  • Oct 19, 2005
  • #30
Is this problem on the shorty BBKs as well? I never knew they necked down so much!
Are there any headers out their that dont neck down so much at the collector?
04sleeper
2,674
14
89
Dallas, TX
Oct 19, 2005
#31
  • Oct 19, 2005
  • #31
Kooks.
OK. I'll try to get them for you. I called him and left a message.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 19, 2005
#32
  • Oct 19, 2005
  • #32
Thanks man for going out of your way to help.
04sleeper
2,674
14
89
Dallas, TX
Oct 23, 2005
#33
  • Oct 23, 2005
  • #33
No Problem Mike.
Sorry for the delay but here it is. He also changed the valve springs but it just extended his RPM due to valve float at around 5580 RPM. You can see the same pattern as the RPM's increase. But you can clearly see the gains throughout the range from the header flange.
Enjoy.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 23, 2005
#34
  • Oct 23, 2005
  • #34
Thank you, I appriciate the help! Those are nice gains through out! Thats impressive since yopu said he still kept a 2.5" mid pipe and all he did was weld on a 3" 3 bolt style collector and whatever he did to make the 2.5" H pipe work. I can't wait to do mine
04sleeper
2,674
14
89
Dallas, TX
Oct 23, 2005
#35
  • Oct 23, 2005
  • #35
No Problem. This is what he did on the header side.
Then he just welded on a 3 bolt flange on his mid-pipe to connect it to.
Good Luck.
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Oct 23, 2005
#36
  • Oct 23, 2005
  • #36
Grn92LX said:
I had a feeling it was you who posted the results, Sleeper. Thank you. I'd like to see near 400rwhp on a dynojet if possible. Regardless, these collectors are restrictions on my combo and most other combo's.
damn, see, this is why i cant talk to you.... you always got me thinking of how to get more power out of my combo! see, you and I have the same headers, similar motor power outputs, and have the same desires. now if i could find out why mine doenst run, id be right with ya
wild_stang04
Dalton, GA
Oct 23, 2005
#37
  • Oct 23, 2005
  • #37
That's a gain of 24.1 horsepower. I believe the new springs played a major role in that kind of gain. In the old run, the power drops off at around 5500. The new run, the power starts to drop off at around 6000, the springs allowed him the extra RPM, and horsepower. Opening up the collector may have gotten him 10HP of the 24 he gained. But what the hell, it's a free mod, there's no reason not to do it.
First Prev 2 of 2
D
Exhaust set up
  • dropteeth
  • Sep 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2025
AeroCoupe
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
W
Codes P2004 & P2005 after removing the Actuators. I locked them open with MMR Plates. How can I fix this? 2018 Gen 3 out of a Mustang GT into a 67.
  • wdsloan
  • Sep 18, 2025
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Sep 18, 2025
wdsloan
W
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
