opinion on heads..........
  • Thread starter Thread starter captahab
  • Start date Start date Sep 17, 2010
C
captahab
14
Barnesville Pa.
Sep 17, 2010
  • Sep 17, 2010
Im going to be buying heads relatively soon and Im not sure what way to go, any opinions would be appreciated. The car has the following add ons.
1986 Mustang LX
Cobra intake.
B303 cam.
Mass Air Conversion.
B&K CAI.
B&K Headers.
MDS Ignition module.
Timing bumped up 13%
24lb. injectors.
Short throw shifter.
Aluminum driveshaft.
3.73 gears.
Frame ties.
rear upper and lower control arms.
Adjustable fuel pressure regulator.
I purchased this car used and the majority of these upgrades were done by the previous owner. I was told the heads were stock and the entire motor was "freshened up".
BiminiBlueLX
37
Tucson, AZ
Sep 17, 2010
  • Sep 17, 2010
Look into the GT40X, Trick Flow Twisted Wedge, and Patriot Freedom Series heads. Those are all good choices. Sounds like this is your only missing link to complete the motor. Good luck!
Jaym14
296
Long Island, N.Y.
Sep 17, 2010
  • Sep 17, 2010
not sure of your budget.. but AFR's are awesome too.
Repostyle
538
Portland, OR
Sep 17, 2010
  • Sep 17, 2010
I usually put them on top.
I like my Edlebrock Performers on my 351.
2000xp8
SN Certified Technician
Aug 8, 2003
8,072
1,656
194
NJ
Sep 18, 2010
  • Sep 18, 2010
Depending on budget, TW's and afr's should be at the top of the list.
Gt40x i would say is next, maybe the newer edelbrock rpms too.
Certainly would not be using anything patriot related, they need hundreds in head work to make them right.
skunk21
1,203
Taxachusetts
Sep 18, 2010
  • Sep 18, 2010
all above or very good options but I'll add these since they don't get mentioned alot, Brodix 5.0.'s. I have seen very good #'s posted from these heads and they are a good long standing company.
FastDriver
I was uncomfortably high & wearing a helmet
Sep 5, 2001
6,231
2,929
224
Vass, NC
Sep 18, 2010
  • Sep 18, 2010
One thing you'll want to do some research on is your pistons. If they aren't notched, I believe '86 had flat-tops, and that might affect your selection. B-cams are pretty mild, but with bigger valves I'm not sure if you'll run into trouble. Hopefully, someone with more experience chimes in.
Chris
skunk21
1,203
Taxachusetts
Sep 18, 2010
  • Sep 18, 2010
Chris
+1 forgot that. either way a PTV check is a must in my book and crazy if not done. just be ready to have the pistons fly cut if needed, chances are the valves are going to be close. even guys who swap over to E7's on the 86 come close but are okay with a b-cam but not all motors are equal and some haven't made the clearance either. I know you don't want E7's just an example, even if you where running true flat tops I would still say check PTV it's just cheap insurance.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Sep 19, 2010
  • Sep 19, 2010
If your car still has the '86 pistons, twisted wedge heads are really your best choice for valve clearance. Anything else will be hit-or-miss. I wouldn't consider that a problem, though, Trick Flow sells a good product. I'll be putting TF heads on my '86 this winter...
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
For Sale 97 Cobra with built 99 cobra drivetrain
  • AvalancheSVT
  • May 14, 2022
3K
SN95 Mustangs For Sale (1994-04) May 22, 2022
AvalancheSVT
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • AmericanMuscle4.6GT
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
T
What's it Worth? 1989 GT - What's it worth?
  • Tim83
  • May 11, 2021
  • What is it Worth?!?!?
3K
What is it Worth?!?!? Jun 3, 2021
Mustang5L5
SOLD For Sale 92 Mustang Notchback Complete Rebuild in 2019
  • pearlnotchback
  • Jun 21, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 24, 2021
Steel1
