OPINIONS/ADVICE NEEDED
blckstng96
208
im haveing a problem with my 88lx.it doesnt like to start on its own and once you get it started it runs horrible.the car will only start on starting fluid and once its running it will idel but very rough and surge a lot.also when you go to drive it it stumbles like crazy and has no power,like its missing and starving for fuel backfiring out the intake.i put a new regulator in it and replaced the map sensor.niether of those seem to help.we had adjusted the timing to because it was all out of wack.so right now im thinking fuel pump but not sure.the fuel pump works because i can hear it but not sure if its working how it should and i dont have access to a gauge to put on it while driving to see what pressure is at under load.i bought the car off a guy not running so im not sure on history of things but i do know he said the pump was replaced thinkin it was that and whoever had replaced it ran the wiring incorrect and the pump goes on and stays on as soon as the ignition is engaged instead of the 20sec or so prime then stop until start.any input greatly appreciated.i just need to get this thing running without dumping a ton of money into it.thanks guys
You don't need to see pressure under load. Check it at idle. Sounds like its low. Will it prime? You should be able to tell by sound. Parts store pumps are junk,and it sounds like thats what you have.
yeah i can hear it prime,it actually stays on as soon as ignition is turned over to acc position.someone must have rewired it.i know it works as far as powering on and stuff but as far as working correctly and having correct presure,thats another story.but its odd because its smells rich but runs like its leans and not getting enough fuel.so im thinking the pressure is low and instead of the normal injector spray pattern its just pretty much dripping and putting out the flame
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
