Maybe this IS tech, but meh...
Here's a list of things I've bought since I've been here, some are for show, some are for a little more oomph, and some are prepping for more serious mods in the future. Take a look, tell me what I'm forgetting, what I might have to look out for in the future, and where I went blatantly wrong...thanks!
BBK Pulleys
3:73 gears
FRPP Alum Driveshaft
MaxSpeed CAI
Smoked Headlights
CGS Subframe Connectors
Custom Ported Intake Manifold
SLP Exhaust
Cobra Bumper/Foglamps
1.25in wheel spacers
B-pillar Floor Bar
Billet Smog Pump Eliminator
UPR Blu Thunder Shifter
AC Eliminator Kit
24 lb injectors
65 mm throttle body
75mm Bullet Pro M mass air meter
E303 Cam (of fury
I still have to pick up my MSD distributor, I don't think the stock unit will do, since I did the last rebuild on it, and I'm rather skeptical about my mechanical ability. I DO need heads, but if i don't buy some, I'll just port the living $#@% out of mine, and see how that does.
As I said, I have limited mechanical skills, and probably less knowledge. Am I headed in the right direction? The good news is, that I haven't gone wingnuts on buying body kits and whatnot, I want to have power before anything....but is there any suggestions on what i can do to ensure that this stuff won't screw me up. Thanks for reading...any help is appreciated
BBK Pulleys
3:73 gears
MaxSpeed CAI
Smoked Headlights
SLP Exhaust
B-pillar Floor Bar
AC Eliminator Kit
24 lb injectors
65 mm throttle body
E303 Cam (of fury
)I still have to pick up my MSD distributor, I don't think the stock unit will do, since I did the last rebuild on it, and I'm rather skeptical about my mechanical ability. I DO need heads, but if i don't buy some, I'll just port the living $#@% out of mine, and see how that does.
), I would get new heads after I got a an R302 or dart block, preferably in the 400+ ci range. I would also go turbo instead of s/c, or at least get an F1 series or bigger procharger. Once you get to a certain power level, you aren't satisfied for long. At least I am not. Going big from the start could save you money if you are going to be addicted. So staying mild on the stock block isn't a bad idea. Also, adding a good turbo kit to a bolt on, stock headed 5.0 will bring you to the limits of the stock block. Then you could get heads after you get a better block if you wanted more.
