Opinions?
Tested the stang once again, got on it pretty good, have some issues I need some expert opinions on, First, when I was accelerating and reached about 5600rpm, car felt like it shuddered or vibrated, what could this be? Too much rpm, or fuel starvation? I have the MSD 6a and was thinking maybe the box had a preset rpm limiter? Anyone know? Would I also have to bump my timing down to 12 or 10 degrees with the box, and my current set up? Thanks for replies. :bang:
:shrug:
The 6A does not have a rev limiter, so MSD created the 6AL which is the same as the 6A just has a soft touch rev control. As far as the vibration, does it feel like a loss of power, (rpm's not getting any higher). I see you plan to upgrade to a 140 alternator, you may need it now. the 6A pulls 1amp per 1,000 rpm. what model is your electric fan. I had one out of a lincoln Mark VIII, and believe it or not, it was drawing almost 50 amps! Stock alternators are only good for about 75 amps (depending on the model). with everything running you might not have enough juice to support the car. If you have the money get a Digital 6. it draws .7 amps per 1,000 allows you to adjust timing from the box, and is more compact with a higher output rating. I know this because I have researched all of MSD's boxes and have decided to use it, because it its the best street box they make. to add your timing has no effect on the box. it delivers energy when the car is supposed to spark, so when ever the spark plug fires, the energy is released. you would have to add a timing control to have the box to affect the ignition system.
