- Nov 3, 2005
- 28
- 0
- 0
I am installing an Eaton supercharger on my 01 Roush and am debating on what parts I should go with for the install. I was looking along the lines of ordering a 75mm BBK throttle body, Ford Racing 30lb injectors, oversized heat exhanger and possibly a Lightning MAF. What are your guys thoughts on this? I'll be making bout 10 to 12lbs of boost with the Chicane kit and am working towards 400RWHP. For sure I will replace the TB, injectors and Heat exchanger but what kind do you guys recommend and is it worth changing the MAF? Any input is greatly appreciated. -Trent
01 Stage 2 Roush Convertible
EATON Supercharger w/ Chicane kit
BBK X-PIPE
4:10 Gears
King Cobra Clutch
MGW shifter
BFG Drag radials
More to come...
BBK X-PIPE
4:10 Gears
King Cobra Clutch
MGW shifter
BFG Drag radials
More to come...
As soon as the car is back together I will be towing it up to Phoenix to get a chip burned for it. I also forgot to add that I will be changing out the fuel pump as well... -Trent
, but between all of the Eaton based major manufactures for the 2V engine (Saleen, Roush, FRPP and AED) the AED provide the best bang for the dollar. Cheaper than either the Roush or the Saleen and will make ever bit as much if not more power and intercooled where the FRPP is not.
