66moneypit said:
I think all 65 GTs were stick
65 GT's can be
either stick
or automatic.
65 K engined cars will all be sticks. Automatics were available in 66.
All K codes will have a 9" rear axle. Can be an open or even a locker.
There can be either an A code 4bbl engine or a K code HiPo. No other engine combination was offered-so no 2bbls or I6 GT's.
Yes, one does not need to have a GT to get the K engine. That was a seperate option. A GT could be added to any normal body style, coupe, fastback, and convertible. A 65 that is not a GT will have the normal falcon like dash, not the round speedo type similar to a 66--unless the car has pony interior then it will get the round speedo and wood grain trim. GT's do not automatically get a pony interior-that was another option to check on the order sheet.
All the same rules apply to a 66 EXCEPT a 66 would already have the round speedo as it was standard for that year.
A standard K engined car (non-GT) will have some of the features of a GT. Specifically a fast ratio steering box and heavy duty springs which were part of the HiPo package. I am not sure if a heavier sway bar was included, but I would believe so.
There are several ways used to ID a true GT. The link mentioned above will help. All the things must be present for it to be authentic. There should be no chrome in the sculptered area of the quarter panel. Probably the best indicator, as mentioned above, is that the frame rails on both sides have special reinforced holes to mount the tailpipe hangers, although a normal non GT K code "might" have them too due to it also haveing factory dual exhaust. I've never verified this.
