*ORDERING TOMORROW*.. is this all i need for my 5 lug disc brake[SIZE=1]again[/SIZE]
ridethe93GT said:
ok i just ordered the 3-2 kit from MM and saw how to hook it up....2 questions.....where will i need the pV plug i ordered from summit at and where does the new PV go?
You have to GUT your STOCK Prop Valve and take the O-ring, transfer it to the FMS Plug and install it. The aftermarket Prop Valve goes on the P/S of the engine compartment where there is a junction connecting the brake lines, remove the junction and install the valve there. Turn the knob all the way in to bleed your brakes, then turn it out all the way, then turn it back in 4 turns for your base line setting and then adjust it from there to fine tune it. Good luck on your project.
