Remove the tweeter mesh material first and then there is a small screw (philips I think) holding that tweeter to the door. Then there are 3 nuts holding the mirror to the door. You can remove two no problem and the lower one with an open end wrench but don't drop it in behind the door trim. Problem is the electrical connector is lower behind the door panel. Now if you look in the workshop manual they tell you to remove the door trim (pain in the azz). You can try and just remove the plastic trim that holds the window switches and reach in behind there to unclip the connector. Worked for me. Good luck.
