Over 2 Years!
  • Thread starter Thread starter 5.0Pilot
  • Start date Start date Jul 26, 2011
5.0Pilot
11
Oxnard, CA
Jul 26, 2011
  • Jul 26, 2011
I've searched on the topic, and I know this has been brought up before but...
I daily drive my 5 speed, and after driving about six miles, she starts stalling whenever its under 2k. At the light at idle she'll die completely, and I have to keep restarting her the last leg of the drive. Same scenario on the way home.
The check engine light will go on and off sporadically, but when I used the scanner tool, nothing was stored. I also went down the list of items to check (TPS, IAC, vacuum lines, replaced coolant temp. sensor and air charge temp. sensor, swapped MAF) but nothing has worked. This is still happening even after I had the engine rebuilt last 5,000 miles.
I know that this has happened to you before, so I would like to hear your story of what your specific issue was and what you did to fix it.
Thanks
Cooner187
41
N.W. Ohio
Jul 26, 2011
  • Jul 26, 2011
I had an old 1975 Mustang II with a 3.8 in it that did the same thing, turned out to be the ECU, don't know if that will help you or not, but it some like it's something electrical... I can remember driving home from work and it would just die and I'd have to put it in neutral and then hit the key to start it again... After a few cranks it would lite up, sometimes it took longer... It was a major PITA!
5.0Pilot
11
Oxnard, CA
Jul 26, 2011
  • Jul 26, 2011
That's what I'm fearing since I have basicaly replaced or swapped every elecrical component under the hood, including O2 sensors... How difficult is it to swap the ECU? What would be an Ideal upgrade that would be compatible for future performance installs?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 26, 2011
  • Jul 26, 2011
You may have overlooked this...
See the "Surging Idle Checklist for help with all your idle/stall problems.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 27, 2011
  • Jul 27, 2011
you did not mention or list the TFI - one failure mode of it is the engine dying and then restarting after a short cool down period. Heat kills the TFI. I just moved my TFI over to the inner fender and have used a heat sensor gun on it - runs at about 130 degrees. Much cooler than the 180-200 degree engine. Ford moved it off the dist in 94 after a class action law suit.
5.0Pilot
11
Oxnard, CA
Jul 27, 2011
  • Jul 27, 2011
jrichker, thanks for the link. I will attempt to pull codes from the ECU, as the dash does flash when the car is doing its unwanted cycle.
tmoss, I should have added that I just did just that and replaced it, along with new O2 sensors, since I swapped to an off road H-pipe. But I guess relocating the module wouldnt hurt.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,187
2,836
224
Vass, NC
Jul 27, 2011
  • Jul 27, 2011
Ignition switch?
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
