Overdrive Button not working...
dr_devious
11
So I installed the UPS Shift Knob and Overdrive Button Bracket on my autotragic and now that overdrive button does not work. I took it apart again and checked the connections and everything is connected. I even went and bought a new OD button from my local dealer. Is there something else I can try or look at before I eat the $100 to have the dealer look at it?
03ghoststang said:
there is a mini fuse if i remember correctly :scratch: that is in conjunctuion with the E-brake i would check there and see if its blown the fuse is in the fuse box in the driver side kick panel. Can't remember the fuse number check the owner's manual
No owners manual so I am flying blind....I will check the fuses. Let me know if you can provide me that....thank you!
