Sorry for the long post, but here it is............
Recently I replaced my P/S pump, during this I noticed my W/P pump had a little leak, so I though might as well replace it. So I did. Started the car and the temp went up to 270(stock gauge). I thought maybe the t-stat was bad replaced it with another 180 from a local chain store, same thing. Then I replaced the temp sending unit, same thing. I noticed the new W/P had a leak toward the back. I ripped it off and got a replacement, reinstalled it, same thing. I though possibly the new t-stat was bad, I went to local dealer this time and got a OEM t-stat with the bleeder relief, still had the same issue. At this point I was running out of ideas, we checked the timing, right on at 10 degrees. I reinstalled the spout connector and went to start the car nothing happened. Dead starter. So today I will be replacing the starter. I checked or replaced all the normal cooling components and it is still overheating. When the car is running you can see coolant circulating, I don't see any hoses, which are collapsed. When the car is hot, probably around 250 degrees, I can test the water in the radiator and it is never more than 160, which tells me the fan is cooling properly. The radiator has about 10,000 miles on it, so I'm thinking thats not the problem. I'm running a 50/50 mix like I have always done. I was wondering if maybe the starter was not disengaging and causing excessive drag on the motor,which is causing my overheating. I didn't hear anything unusal from the starter though. I'm out of ideas over this one. Any help or suggestions would be greatly appreciated. Thanks.
