Overheating Problem: Please Help!
cobretti
12
Hey everyone:
Worked on the car on Sat and fixed one problem but found another one. :mad:
Car is a 1985 former V6, now powered by a 1992 5.0.
After fixing a transmission pan leak I wanted to test drive the car. So I fired up the car to check for leaks. I was happy to see that the transmission was no longer leaking but did see a small puddle below the passenger side of the car. I checked it out and it felt like water (a little oily) and noticed it was dripping from the little drain tube on the firewall. This struck me as odd since I had removed completly the AC. I ignored it and took it for the test drive. Car ran and shifted great. I decided to take it on the highway. Got on the highway and got on it and that is when I noticed the temp gauge reading really high :notnice: just before the red line on the L of NORMAL. KEEP IN MIND the temperature outside was 95 degrees. (I don't know if this makes a difference).
So I turn on the heat and get home ASAP. I get home and check and see no coolant leaks. There is however a steady drip from the drain tube bouncing off the exhaust. :shrug:
Now, I remember my father taking off the raditor cap while the engine was running when I first finished the tranny pan gasket. I am wondering if this caused the car to run hot.
I am just nervous becuase I have heard that liquid coming from the drain tube is not a good sign.
Anyone have any ideas suggestions?
Looks like you might have a heater core on its way out. Do you smell it in the air when you turn on the heat or defrost? Does it fog up your windshield? Mines on its way out and I get a drip from that tube right onto my passenger side exhaust. Smells GRREEEAT!
There are a number of factore that can cause your car to overheat. The headgasket could be blown, the radiator cap could be bad, if your running dual cooling fans sandwhiched thats not good, because the one fan pushing and the other one pulling not allowing the air to flow through the radiator and causing it to sit there.
