Well it has been DAMN hot these last few weeks (100-112^). My car now reads around 210^ in this weather. During the night when it's 90^ she reads 195^. Am I overheating the engine? Fans are kicking on for sure...
210 is close to the upper limit of normal range for a modern EFI engine. 220 is considered the start of overheating and when heads can start to warp and be damaged.
Time for a rad flush and 50/50 mix with water wetter if it's been over 2 years since the last flush
WHOA - that engine temp is pretty high. I don't have a temp gauge that has degrees(there's a way to monitor it on my LiveWire, I'm just not sure how yet) - but based on the outside temp here in Jax, FL (low 100's with humidity) and based on the fact that my engine temp gauge never moves past the middle - I would say you're having an overheating issue. Have you changed out your theromstat? Ever done a radiator/coolant system flush or vacuum? Oil + Filter change?
Im not trying to be rude or anything but those damn fancy idiot lights ford put in as gauges are complete
They always read in the middle even when they shouldnt.Ex:my volt gauge reads at the mid point all the time but my battery was pretty much gone...it read the volts were good...turned the car off and went into store for 10mins....come out and it was dead(on my old gt).Now with my real gauges installed the water temp varies a whole lot while driving around town and the stocker never moves.....half water/half water wetter? I've never heard of this? It may reach below 32 degrees here in jacksonville for two or three nights per year. What would be the benefits of me using the water/water wetter as opposed to straight coolant?
Water wetter is a product which increases the thermal efficiency of water. The original poster lives in climate that doens't freeze..so he needs no antifreeze. The benefit would be is it keeps your car cooler...that's the point of this thread right?
Red Line Oil: Coolants and Others
Water wetter actually reduces the surface tension of water allowing bettwe heat transfer. It works like dish soap does...but you don't want to fill your rad with dish soap.
i too live in the desert, and get outside temps of 112+, but I usually cycle through 190 degrees to 210, at which point my fan catches up and throws the temp back down.
i was lucky and my gasket failed before my heads did lol+1 on the half water/half water wetter. You shouldn't need any antifreeze since you live in the damn desert lol.
