p/s pump help asap please
The hex is not a bolt, it's part of the power steering pump shaft. The pulley is pressed onto the shaft, and it's a pretty tight fit. You need a power steering puller to remove the pulley, and an installer to press the pulley onto the new pump.
ou will need to rent or buy a PS steering puller. The PS pulley has a ridge that the puller seats on. Then you crank the screw on the middle of the puller to get the pulley off the shaft.
You can rent the tool at Autozone or other auto parts stores.
I have used a bearing separator & harmonic balancer puller together to do the job.
Use this tool to put it back on...
I usually just use the bolt that comes with the new PS pump.
type f?? i thought that was only used on the thompson style pumps. our cars use the newer style with plastic reservoir. i was told by the dealer to use atf type 3 and not that clear "power steering fluid" crap from the auto parts store.
If you own a Fox Stang it takes Type F Fluid, I believe 96 or 98 was the change off of Type F.
