alright im starting to do my rack & pinoin/ps pump/ spring swap and i cant get the old pump off, it wont slide all the way off the bolt that holds it on because it hits the fan shroud. anyone know how to get it off?
I dont recall removing the fan shroud or having that issue. If Brandon thinks it's possible, then go for it. Otherwise, I was thinking that to make sure you're removing the correct bolt.
yeah i have all the bolts out, the thing stopping me is that the stud is too long for the pump to slip off over it without hitting the shroud. is there anyway to take the shroud off without taking the stock fan out? or do i just have to unbolt the fan and then unbolt the shroud?
Since you already have the belt off, it doesn't take but about 10 minutes to remove the fan & shroud. The fan unbolts and then remove the shroud. It almost takes longer to tell how to do it than to do it.
Just remove the stud, atleast that's what I did. If you don't need the stud anymore throw a vice grips on there, otherwise just throw two nuts on there and back it out.
