• Community Forums
  • The Welcome Wagon
P0171 And P0174
  • Thread starter Thread starter Stillbetterthanchevy
  • Start date Start date Jul 4, 2016
  • Jul 4, 2016
Hey guys,
I am new to this site and I am having some trouble.
I have a 1998 mustang gt that I got about a month ago and am having problems with. When I got it, the AC compressor wasn't kicking on, the power steering pump was leaking at the shaft, the front bearings were bad and the starter was only kicking on intermittently. Also, coolant was leaking out the intake manifold. I replaced all these things and when I started driving it. I got 3 codes. Cylinder 4 misfire and bank 1/bank 2 system too lean. The misfire was because I got coolant down the spark plug tube, so I just replaced all the plugs (which was going to be done anyway) and that went away. But no matter what I do I can't get the lean codes to leave. I don't think it's the o2 sensors because I figured that it was not likely they would go out together.
I checked the fuel pressure and I was at 20 PS at the rails, so I changed the filter and was getting 30 PSi. I still thought that was low and so I changed the pump. Still reading 30 psi. I unplugged vacuum off the regulator and the readings didn't go up so I figured that was bad. Changed it, now that works, it went up to 38 psi with no vacuum. But Im still getting the codes! Is that normal pressure to have? Keep in mind that I do have a return. This whole time I've been monitoring my fuel trim and ltft is at 25% on both banks and stft is usually around 7.
The oxygen sensors are reading fine, it's just that occasionally the upstream sensors drop to 0V.
I put vice grips only return line to raise the pressure at the rails and that brought my fuel trim way down. Ltft was at 1ish% and stft was hovering around -10%.
I checked for vacuum leaks, over and over but couldn't find any. Clamped all my hoses anyway.
I also cleaned the maf with maf cleaner. Nothing.
I even warrantied the new intake manifold because I thought that it might be cracked, but the codes still came up! I'm at my wits end!
On an unrelated note, the AC was working fine, but I put some more oil in it because some spilled out while filling it and now the clutch won't engage. Low side is reading approximately 100 psi. Any ideas?
Any help is much appreciated. Sorry if I missed some info. If you need more info, just ask. Thanks so much for looking over this!
Davedacarpainter
SN Certified Technician
Nov 28, 2015
11,833
11,634
203
Discordia
Jul 8, 2016
  • Jul 8, 2016
Stillbetterthanchevy said:
Hey guys,
I have lots of ideas about your problems, but you should really go to the subforum for your mustang. The subforums are based on body type and year range.
Go to the tech section first and basically repeat this post there. I'm sure you'll find help there.
This area is more of an area just to say hey to everyone in general, from '64 to '16 mustangs.
Welcome though brother.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Community Forums
  • The Welcome Wagon
