  • SN95 V6 Mustang Tech
P0340 code
  • Thread starter Thread starter giuseppe1979
  • Start date Start date Jul 30, 2011
G
giuseppe1979
  • Jul 30, 2011
i have a 2004 mustang. hood label says 3.8L block label says 3.9L so not sure which one it is. ses light came on and come to find out it was the camshaft position sensor. replaced that and had alternator tested. now 2 days later light came back one. anyone have any clue what it might be
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 30, 2011
  • Jul 30, 2011
Did you use the correct sync tool when re-installing the cam sensor? If not, likely this is your issue.
Check out the following for more information on replacing the cam sensor.
Replacing Camshaft Synchronizer & Sensor - Ford Mustang Forums
G
giuseppe1979
  • Jul 31, 2011
thanks for the info i will be sure to look into that
Cant Figure Out P0340 Issue
  • Blackout67
  • May 31, 2025
SN95 V6 Mustang Tech Jun 8, 2025
Blackout67
M
Cam Position sensor code
  • Miller205
  • Nov 29, 2024
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Dec 1, 2024
Dino Dino Bambino
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
