  • SN95 4.6L Mustang Tech
P0781 1-2shift code help?
  • Thread starter Thread starter krooxstang
  • Start date Start date Nov 1, 2011
K
krooxstang
Wichita, KS
Nov 1, 2011
  • Nov 1, 2011
I have a 2000 GT auto and I just had my O/D light start flashing so I hooked my SCT tuner up and it thru the code p0781 1-2shift code. My car is NOT shifting any different, not hard, no noise or anything. I called american muscle tuning department and its weird considering it shifts normal. I am going to return the car back to stock and see if the problem persists but I want to know if anyone has any input on this issue. It started happening a day after a coyote came out of the ditch and t-boned me in the driver side door. It just hit my door and a little bit of my front wheel well. I hope its not a big issue but we will see
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 1, 2011
  • Nov 1, 2011
P0781 SSA or internal parts 1-2 shift error
The Ford workshop manual in Section 307-01 has a fairly long pinpoint test for this DTC. Much too long for me to post.
Have you inspected the gear selector under the car to see if it was damaged?
If you are interested in getting a copy of the Ford workshop manuals, wiring diagrams, and PCM manual for your car, I maybe able to help. PM if interested
P0781 b
1-2 shift error
Engine rpm drop not detected when 1-2 shift was commanded by PCM.
Incorrect gear selection depending on failure or mode and manual lever position. Shift errors may also be due to other internal transmission concerns (stuck valves, damaged friction material).
REFER to Solenoid Operation Chart. Go To Pinpoint Test A .
K
krooxstang
Wichita, KS
Nov 1, 2011
  • Nov 1, 2011
Well...I put the car back to stock with my SCT Tuner and the light didnt come on or anything. I will assume I need some new tunes so I will have to wait. My car is in the body shop getting it fixed from having a coyote run into me on the highway. I am having the shop look at the gear box thing under the car and check all the wiring. Will keep ya updated
nyuk98gt
1,427
Chesterfield, MO
Nov 1, 2011
  • Nov 1, 2011
krooxstang:
Don't you see it, man? It's sooo obvious... the COYOTE running into your Mustang... is a sign from on high that you need to put a 5.0L engine into your Mustang. Amen.
I bet the MLPS got a little out of adjustment, especially if traces of coyote bits and pieces are on the underside of the floorpan.
HTH,
Chris
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
2001 GT stuck in 2nd
  • 01gtslider
  • Jul 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
01gtslider
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
