P1635 FRom ABS light??????
Do you have different tire sizes (diameter) on the back from the front? The front/back tire diameters have to be within a certain percentage of each other (8% I think). If too much difference, the ABS sensors think that the wheels are slipping because of the the different sizes.
Do you have a custom tune? How about a different axle ratio or non-stock tire diameters?
An yes, the P1635 DTC would be related to ABS problems.
P1635 - Tire/Axle Ratio Out Of Acceptable Range
This Diagnostic Trouble Code (DTC) indicates the tire and axle information contained in Vehicle ID block (VID) does not match vehicle hardware.
Incorrect tire size
Incorrect axle ratio
Incorrect VID configuration parameters
Using the scan tool, view the tire and axle parameters within the VID. They must match vehicle hardware.
This problem is more than simply programming the PCM with the correct tire size. Because of the size difference between front/rear, the axles are rotating at different speeds. Further, the ABS system assumes the front/rear tires are the same diameter (the PCM does not have the ability to specifiy different diameters for the front/rear).
Maybe someone else can chime in on exactly how much of a mis-match ABS will accept. I thought it is 5-8 percent.
