Paint/prep help and how to install S281 Spoiler (99+)
  • Thread starter Thread starter stang2004
  • Start date Start date Apr 11, 2007
1 of 2 Next Last
stang2004
177
Northern Jersey
Apr 11, 2007
  • Apr 11, 2007
Ok, so i purchased a Saleen S281 Spoiler for my 03 GT. It is the wing only. No hardware, light, instructions, etc.
First.
I am thinking of doing the prep work myself to save money. I have read before that there is no reason why ya shouldn't. I know the basics of Paint/Prep etc. I was wondering if anybody has a good article with a How to, that gives a good step by step through the prep and paint process. (I'm also planning on doing my side mirrors)
Secondly, there is no instructions
Can anybody point me in the right direction on how to install? Hardware? 3M tape?
Thirdly.
Where can i purchase the 3rd brake light without being raped. And is there a specific hardware kit that i need or can i pick this stuff up elsewhere.
thanks
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Apr 11, 2007
  • Apr 11, 2007
Installing the S281 wing is tricky. If you're doing the paint and prep yourself, make sure that your paint is SUPER STRONG because an insane amount of bending will be required to fit the wing on. If the paint is not thick/strong, expect the paint to crack as you push that wing down to make it flex to slide over your trunk.
Let me see if I can still find my instructions and if I do, I'll scan it or post it here.
stang2004
177
Northern Jersey
Apr 11, 2007
  • Apr 11, 2007
Sounds good. Any tips or advice to help me out would be awesome as well. Cuz all i have is the wing sitting in my garage, and im going about this blindly.
Is there a special filler/primer etc that i should use? Flexible filler im assuming?
And why would there be bending involved? From what it looks like, is that the outside lip gets some 3M tape, and the wing gets laid down over the rear of the trunk lid, and the screw holes hopefully line up with the holes in the trunk.
Everything always seems simple but turns out to be a pain
TrueBlue03
372
Bay Area, CA
Apr 11, 2007
  • Apr 11, 2007
have fun with that...i hope you got a good one, if not, you're in for A LOT of prepping, sanding, bending and screwing
Saleen311
67
Hampton, Va
Apr 11, 2007
  • Apr 11, 2007
thats one more reason why i recommend the 351 over 281
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Apr 12, 2007
  • Apr 12, 2007
not really super strong paint, but mix flexing agent with it.
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Apr 12, 2007
  • Apr 12, 2007
I just got me a S281 spoiler for my 98 GT -- I test fitted it today, and it lines up great. I just need to know how to prep/paint it. I have a basic air paint gun!! Will that help?!
AmBo
1,027
New Jersey
Apr 12, 2007
  • Apr 12, 2007
that's why i'd buy the abc 281 over saleens. pos...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 12, 2007
  • Apr 12, 2007
Take it to a body shop and let them deal with it.
02LaserRed2V
379
Augusta, GA
Apr 12, 2007
#10
  • Apr 12, 2007
  • #10
I hate mine. It still sags. Someday I'll probably just replace it with the 03 Cobra spoiler..
stang2004
177
Northern Jersey
Apr 12, 2007
#11
  • Apr 12, 2007
  • #11
where can i buy the brake light for this spoiler?
Saleen311
67
Hampton, Va
Apr 12, 2007
#12
  • Apr 12, 2007
  • #12
I have one on my old 281 spoiler but I dont remember if all the lights worked correctly
stang2004
177
Northern Jersey
Apr 12, 2007
#13
  • Apr 12, 2007
  • #13
PMed
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Apr 12, 2007
#14
  • Apr 12, 2007
  • #14
if youre really going to tackle it, make sure you mask off every area in the rear, when i mocked up my 281 to do the holes man even trying not to scratch the rear i tore up the rear decklid pretty good. its a pain in the ass and will fight you the entire time.
btw i also do plan to sell mine for a 03/04 termie lip.
Turbo92PGT
746
Auburn Washington
Apr 12, 2007
#15
  • Apr 12, 2007
  • #15
So does the ABC s281 spoiler fit better than the saleen? I'm a bodyman and can make either of them fit but I would rather not have to mess with it. How is the finish of both? I dont want tons of filler and primer to deal with.
Thanks
Andy
TrueBlue03
372
Bay Area, CA
Apr 12, 2007
#16
  • Apr 12, 2007
  • #16
thomas91169 said:
+1
I KNOW THE FEELING!!! same thing happened to me. had to get my trunk lid repainted! the damn thing was also permanently bent to one side when i tried to get it to sit flat on the trunk.
And my rear LED's are still not working properly for some reason...my wiring must just suck.
**and NOTE that the pre 99 saleen spoilers are completely different and end up fitting a lot better than ours from what i've heard...
TrueBlue03
372
Bay Area, CA
Apr 12, 2007
#17
  • Apr 12, 2007
  • #17
double
T
tangerine96gt
Tyler, TX
Apr 12, 2007
#18
  • Apr 12, 2007
  • #18
are the fitment issues the same between the 99-00 and 01-04 styles?
stang2004
177
Northern Jersey
Apr 13, 2007
#19
  • Apr 13, 2007
  • #19
I'm very confused. I guess im going to have to try mocking it up on my GT and see how the fitment is then? From what i see and read is that the wing is mostly held down with 3M doublesided foam auto tape. And that there are two screw holes in the bottom of the spoiler which line up to the holes in the decklid.
I was personally just going to do the prep/filler work. Then let a autobody shop lay down matching paint. Then install the spoiler.
If it is infact bent or warped, what could get it back into shape? Heat gun? Let it sit out in the hot sun?
Any tips on any part of the installation would be awesome. I dont want to have to take my whole car to the body shop just for a wing install, and not have my car for a week.
Seraphitia102
Oct 11, 2004
737
California
Apr 13, 2007
#20
  • Apr 13, 2007
  • #20
I still have to locate the instructions, but yeah, there's bending involved because if you fit the wing on your car right now, the hole on the wing won't align with the keyhole on your trunk until you bend it.
You should definitely use the urethane flex additive before painting. That'll help keep the paint stable when you're bending/flexing the wing to fit.
1 of 2 Next Last
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
SOLD [Minnesota] 2014 Ford Mustang GT | Grabber Blue | 6MT Coupe
  • Mycelus
  • Mar 20, 2023
  • S197 Mustangs For Sale (2005-14)
6K
S197 Mustangs For Sale (2005-14) Mar 27, 2023
Mycelus
Progress Thread 94-95 Tail Light Restoration
  • 1994GT5.8L
  • May 28, 2018
6K
1994 - 1995 Specific Tech May 28, 2026
from6to8
R
Help with sequential taillights
  • Rene C
  • Aug 14, 2018
2K
1996 - 2004 SN95 Mustang -General/Talk- Aug 16, 2018
Rene C
R
