Parking Light Bulb Socket
Hey guys,
When i was removing my stock headlights today to replace the headlights with smoked ones and new bulbs. When i pulled out the parking light bulb for the driver's side parking light, the light bulb broke and the bottom metal part was left in. After many attempts to remove the metal part I ordered a replacement one from 5.0 Resto. (http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-13411A 1&comp=LRS).
So my question is how do I remove the wires from the Parking Light bulb socket? Its hard to see what I have to do with all of the grease. From the looks of the 5.0 resto picture I have to bend the metal tabs to release the wires?
Please help!
I am pretty sure NAPA has the socket you need and I think there are wires already on them I would cut your old one off and solder the new one on. The one you orderd will have the same connectors the stock one has/had and they look to pull apart.....try a little brake kleen and then you should be able to see what you need to do better.
you know theres a small metal clip the holds the base of the bulb in that socket dont ya? if you havent removed that clip thats why it isnt coming out. if you removed the clip get a screwdriver and tap on the back of the socket till it falls out.
89streetbeast,
I have not had a real chance to look at the socket but I can see the metal clips. I will try to remove the clips tomorrow.
didnt mean to sound rude or anything, if it did im sorry for that lol. those little clips, just take a small flat screwdriver or a pic and pry out one side and pull it out. pretty simple :nice: that way you dont have to buy a new socket lol.
