parking light
  • Thread starter Thread starter 50foxbody
  • Start date Start date Jan 13, 2009
50foxbody
218
  • Jan 13, 2009
i replaced my parking light 3 days ago and on my way home from work i notice that my blinkers were not working they stayed lit... let me know if you can help thanks
50foxbody
218
  • Jan 13, 2009
ID89GT
1,659
18
49
Spokane Valley, WA
Jan 14, 2009
  • Jan 14, 2009
Your question is too confusing.. lol
dcurtis
688
Jan 14, 2009
  • Jan 14, 2009
Did you check the flasher? That would be my first guess or maybe a wrong bulb installed.
Beasty306GT
671
Oxford,Mass
Jan 14, 2009
  • Jan 14, 2009
probably the flasher....or maybe a bad ground somewhere
50foxbody
218
  • Jan 14, 2009
how did i check it just go through all the bulbs?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 14, 2009
  • Jan 14, 2009
The lights up front all use a single ground wire that bolts down on the top radiator support near the radiator hold down bracket. Make sure it hasn't broken off or come loose. There is one ground wire for each side.
In the picture the ground wire is near the 2005 date.
Passenger side shown, driver's side ground wire is in a similar location.
50foxbody
218
  • Jan 15, 2009
yea so i replaced the flasher and i looked at those groungs come to find out they went to my high beems idk im confused
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 15, 2009
  • Jan 15, 2009
One single ground per side serves the parking, headlights and turn signals.
No info about your car's model year, EFI or carb, no mods listed. Makes it hard to troubleshoot when we don't know what you have.
Therefore, no clue as to which wiring diagram you need. The wiring changed several times between 79 & 95.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
AutoZone wiring diagrams
AutoZone.com | Vehicle Selection - Year for 79-88 model Mustangs
AutoZone.com | Vehicle Selection - Year for 89-93 model Mustangs
AutoZone.com | Vehicle Selection - Year for 94-98 model Mustangs
50foxbody
218
#10
  • Jan 15, 2009
  • #10
alright now i changed it sorry for all the confusion... and thanks for the help... do you guys think my indicator switch went bad?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 17, 2009
#11
  • Jan 17, 2009
  • #11
If your problem only affects one side, you have some wiring problems associated with that side. Look closely at the wiring, grounds and connectors for that side.
If the problem affects both side the same way, you have problems with the switches or switch wiring. Look closely at the multifunction switch and its asscoiated wiring. A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-98 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it .
Other possible problem sources for the turn signal malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
Specific diagram for your car's lighting circuit...
E
Red Theft Light stuck on when parked only
  • Eightiesrock1980
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Eightiesrock1980
E
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
