Parking Lights
  • Thread starter Thread starter Cobra136
  • Start date Start date Apr 19, 2007
Cobra136
  • Apr 19, 2007
ok, so i tried searching for it here but found nothing. I have a problem with my parking lamps (front and rear) not shutting off. Ive swapped the switch with one from my lx and pulled the fuse and they wont shut off. Only way to shut them off is to pull the battery cable :S Any help/hints would be much appreciated
HISSIN50
34
129
Apr 19, 2007
  • Apr 19, 2007
Is there a short in the headlight switch connector? Do you have an aftermarket alarm? A relay being latched from an alarm install sounds like a pretty decent possibility to me, especially if you test the parking light wire at the headlight switch (brown wire, IIRC) and it's not hot, yet your marker lights are on.
Good luck.
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
