Parking pawl problem?
  • Thread starter Thread starter other_shoe
  • Start date Start date Jan 6, 2012
O
other_shoe
313
  • Jan 6, 2012
Hi, all.
Today I got into the car and heard a click and it started to slowly roll backwards with a few more clicks, all the while with the lever in Park. I didn't have the parking brake engaged because I'd cracked the cheap plastic handle, but that is another problem. I put my foot on the brake to stop the roll and pulled the lever out of park and then back into it, at which point it held the car in place. I tested it out on a different slight incline and found that the car will hold in place without the parking brake, but any additional force makes it start to slip.
I'm guessing that either the pawl or the gear it engages is worn, but I also wanted to run it by you all to see if there are other things I should look out for.
Also, it's not likely related, but the neutral safety switch or something is malfunctioning because I cannot start the car from neutral and the electrical for various accessories cuts out sometimes when I shift through neutral during parking.
Thanks in advance for your suggestions.
horseballz
824
Las Vegas, NV
Jan 6, 2012
  • Jan 6, 2012
May be a slight mis-adjustment of shifter?
Gene
O
other_shoe
313
  • Jan 6, 2012
Gene
I'd be pretty happy if adjusting the shifter solves it. I'll check it out tomorrow.
65fastbackresto
1,229
AR
Jan 10, 2012
  • Jan 10, 2012
+1 on the shifter, sounds like the linkage is just a little bit off.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jan 10, 2012
  • Jan 10, 2012
I'd be very surprised if the pawl or ring gear were damaged. Your most likely culprit is a loose retaining nut inside the case allowing for slop in the shifter. Also check the case bushings where the shifter assembly rod exits the case
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Parking brake cable
  • Scrapla347
  • Nov 30, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2024
Scrapla347
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
