pass side switch no workie
  • Thread starter Thread starter billison
  • Start date Start date Jan 1, 2007
billison
I like tinted tail
2,607
1,094
184
stl
Jan 1, 2007
  • Jan 1, 2007
Ok, I've rechecked the wireing with a diagram and i have the windows wired right, and i've changed the switch but the passenger side switch does not work, I can contoll all 4 windows from the drivers side but nothing on the passenger side, locks dont' work either if that matters
89streetbeast
365
horton,ks
Jan 1, 2007
  • Jan 1, 2007
i'd check the actual switches (part you flip up and down) to see if they are bad. swap one from the drivers side over to the pass. side and see if it works.
billison
I like tinted tail
2,607
1,094
184
stl
Jan 1, 2007
  • Jan 1, 2007
I did, i changed it out with 3 other switches i have laying around
89streetbeast
365
horton,ks
Jan 1, 2007
  • Jan 1, 2007
ok, on the pass. side switch wiring for the window, there should be:
red/yellow stripe and yellow/red stripe, those 2 are for the window motor.
yellow/black stripe, red/black stripe and a pink wire, those are for the controls of up and down movement. i think the pink wire is the hot cant remember.
take a test light and see if when you flip the pass. side switch up and down that the yellow/black and red/black wires light up. if you dont get anything there and the pink wire is hot, somewhere in the harness is a broken wire. hope i explained it a little better lol.
billison
I like tinted tail
2,607
1,094
184
stl
Jan 1, 2007
  • Jan 1, 2007
I took a test light to it befor and i got ground but no power..I'll try to run power to the pink and see what happends
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
