- Nov 1, 2005
- 57
- 0
- 0
I Just bought my 91 5.0 gt last week and im trying to fix one of the many small problems with it. The passenger side window would not go down so i pulled the door panel and pulled to motor and relized the motor would still go up but not down. So i then switched the pass motor with the drivers side motor to see if the motor was the problem and the pass motor went up and down. I then switched the motor back into the pass side and used the drivers side window switch (which i know works) and it still did not go down, only up. Therfore its not the switch or the motor, but the problem is somewhere in between. There is also no connector for the switch assembly as ive seen on other stangs, it is just straight wire ran through out the door. Anyone know what it could be?
Also i forgot to mention the drivers side switch for the pass window will not make the pass window go up or down. i also changed that switch with the drivers side window and the switch worked to operate the drivers side window. All in all, all of the window switches themselves work
Only my drivers side works from the switch..
