Passenger Power Window Not Going Down But...
ricgt88
255
Quebec, Canada
Hey guys,
My passenger power window is no longer going down. It is working when I use the drivers switch but not the passenger's so I know the motor is good. I replaced the passenger switch but it still does not work.
Any ideas?
The problem is probably the switch on the drivers side if you have no power on the pass side, both switches have to have a neutral position to allow current to flow so that you can control the window from either side,they actually reverse power sent to the other switch, I know this may sound confusing but more than likely it is the drivers switch.
