passenger side window problems
  • Thread starter Thread starter jmd2914
  • Start date Start date Nov 9, 2007
J
jmd2914
937
Napa, California
Nov 9, 2007
  • Nov 9, 2007
my passenger side window will only roll up and down if you use the button on the drivers' side. so just to clarify this would mean that its the switch on the passenger side that went out right? just tryin to narrow down what i need to look at before i tear my door pannel off tomorrow night.
thanks in advance guys
Joel
baldy1
124
Portsmouth Va
Nov 9, 2007
  • Nov 9, 2007
More than likely yes.
trbkrb
1,976
Houston, TX
Nov 10, 2007
  • Nov 10, 2007
Might be able to take it apart and clean it. Just watch for the springs in it. I did that and got mine to work again. You can also use the lock switch in it's place to test it. They are the same basic switch, but the plastic locating tab is different. I just cut the tab off the lock switch and then it will fit in any lock or window switch location.
If you need an new one, I noticed my local O'Reilly Auto had them in the "Help" parts section for like $12 each. Might call around to see if a local place has them.
SuperStang83
1,693
Boyertown, Pa
Nov 10, 2007
  • Nov 10, 2007
Most likely that is your problem. You should test it with another switch to make sure though like trbkrb was saying.
jammer84_03
468
  • Nov 10, 2007
like ss said. i had a heck of a time this summer with my wiondows. (props to hissin for the help there), but i would take a meter and check and see if is a wire as well. test first, spend later. gl man
StangCrazy302Gt
282
New Jerzy
Nov 11, 2007
  • Nov 11, 2007
i had the same problem , it was the switch
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Yesterday at 10:26 PM
AeroCoupe
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical Fried my window motor…
  • AnthonyA1234
  • Oct 25, 2024
Fox 5.0 Mustang Tech Oct 26, 2024
General karthief
