  • SN95 4.6L Mustang Tech
Pats is my problem...
  • Thread starter Thread starter 01mustgt
  • Start date Start date Nov 8, 2010
01mustgt
sweeny, tx.
Nov 8, 2010
  • Nov 8, 2010
i have a 2001 mustang gt. a series of test have been run on it and the diagnosis is pats. my theft light blinks rapidly even when i crank it. if the key is left on for a while the light blinks 1, pauses, blinks 6, pauses long, then repeats the sequence again. what do i do?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 8, 2010
  • Nov 8, 2010
If you have a second key try that , if not you will probably need to get it towed to dealer to have the pats system reprogrammed and possibly a new key if the chip in your key went bad , if you had a tuner or some sort you can get the PATS disabled but the theft light blinks all the time if you disable the system
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 8, 2010
  • Nov 8, 2010
How to troubleshoot PATS 99-04
So what were the results of the "cluster diagnostics" tests called out in the previous post?
Did you attempt to reset the anti-theft system by unlocking the driver's door with the key or with the remote FOB?
Ford TSB on diagnosing PATS
http://www.stangnet.com/images/stories/docs/sn95_TSBs/01-06-02.pdf
How to access cluster diagnostic mode:
Diagnostic Mode - Ford Mustang Forums
Very good link on how to access the cluster diagnosis. Also includes error codes.
Mustangworld HEC Instrument Cluster Diagnostics
Write up on PATS "blink" codes.
http://www.fordscorpio.co.uk/pats.htm
FWIIW, a blink code of 1-6 is "Faulty link between PATS module and EECV" Which suggest that the PATS module and PCM may not be programmed to "know" each other. Have you replaced your PCM or cluster? Done any recent wiring work?
01mustgt
sweeny, tx.
Nov 9, 2010
  • Nov 9, 2010
it was the pats not recognizing the pcm. when i checked the pcm the harness wasnt screwed in just only pluged so now we have a working mustang. appreciate all of the help. very usful information on everything you all told me. today i went and looked at another mustang. a 2004 mach 1 and i did the test holding the odometer button and seen some codes the dealer was trying to hide.
GDawg
1,469
Nevada
Nov 9, 2010
  • Nov 9, 2010
Nice links WMB!
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
E
Pats antiitheft-bypass (ez fix)
  • ETindall
  • May 19, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 19, 2026
ETindall
E
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
Resolved 1996 PATS help needed
  • Bajaboy
  • May 21, 2025
SN95 4.6L Mustang Tech May 23, 2025
Bajaboy
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
