i was checking for a vacuum leak around there and found some hoses loose. there is a hose from a vlave on the driver side rear corner of the upper intake, when i was gonna remove it to get better access to the pcv valve and hose, i notice everything was dryrotted and broken off.
well i found the vacuum leak from all the dryrotted hoses, but now i cant figure out where they cam from, i know the hose from the pcv valve runs under the middle of the upper intake. but the other hose that comes from the driver side rear corner valve where does that go. i think it t's off the pcv vlave hose but not sure. i dont know if what i just wrote makes any sence, but does anybody have a diagram or pic of this so i can see. or just explain?
i went to the dealer but there computer diagrams show the pcv system of a pre 94 engine, got into and argument with them cause they said its for a 95 casue the heading said but the picture was a 93 and before intake
they even pulled a diagram of the pre 94 302 that the crown vic had with the intake facing the other way and they said its the same for the 94-95 302, i was like you guys are stupid
but forget can anybody help me with my problem?
