PCV delete/replacement.... Filter??
you can't just run a breather and a pcv system at the same time. If you want to run open breathers you need to block off and eliminate the pcv valve/line and remove and block off the oil fill hose.
Removed the pvc valve a while back and the oil fill hose. Still had the oil fill fitting and it was a pita to fill with oil...:) had to put a tube on it when I did that. But I have one hole in each valve cover, oil fill in one and a pcv hole in the other. (sized by grommet)
Could change the pcv to a larger grommet and get matching oil filler caps?
As a side note: I am wondering if the oil filler hole was releasing any pressure ... i have a blower.
Steve
